1996 Dodge Caravan
70,000 MILES • V8 • 2WD • AUTOMATIC
JIM DUGON
VAN CRANKS OVER BUT WON'T START
Jan 22, 2009 at 4:14 PM
  • 75,988 POSTS
Do below and tell me what's missing fuel or spark we start here
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jan 22, 2009 at 4:24 PM
