1996 Dodge Caravan
222,750 MILES • 6 CYL • 2WD • AUTOMATIC
TEROSHA
I really hope someone out there can give me some idea as to how to fix my van. After the engine gets warmed up, it will just stop while driving down the road. Sometimes I'm fortunate enough for it to crank back. Others, not so much. It won't crank back until after it has completely cooled off. I have put a new fuel pump, crank sensor, and camshaft position sensor in it. After the camshaft sensor, it actually will start but it still dies going down the road. We're currently checking on computers. Please help!!!
Nov 13, 2009 at 10:32 AM
BMRFIXIT
  • 19,053 POSTS
Open hood and locate relay and fuse box
locate inside an ASD relay
remove and replace
give it a test
Nov 13, 2009 at 10:44 AM
TEROSHA
Thank you. But already did that as well. I replaced the ASD relay, Fuel relay, and the EATX relay. Runs just as bad as before. =( Thank you for the help though.
Nov 13, 2009 at 11:27 AM
BMRFIXIT
  • 19,053 POSTS
SO Every thing was done
only thing left is the PCM
good luck
Nov 13, 2009 at 12:00 PM
