1996 Dodge Caravan
SBURROWS63
Electrical problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
where is the fuse for the cruise control located?
I looked at fuse box under left dash and the Power Distribution Center and there is nothing listed for the cruise control.
Oct 18, 2009 at 8:36 AM
CARADIODOC
  • 34,414 POSTS
You should consider including a description of the problem. I'm guessing your cruise control doesn't work. Suspect a broken clock spring under the steering wheel. If the horn doesn't work also or the air bag light on the dash is on, that would be further proof of a broken clock spring.
caradiodoc
Oct 19, 2009 at 6:12 PM
