1996 Dodge Caravan
136,000 MILES • 6 CYL • FWD • AUTOMATIC
JMP1984
i have a 1996 caravan with a 3.3 and everything was great till the trany blew so i got the tranny fixed when ii picked it up i noticed a few things first off i had a engine light on #2 my rpm tac was shaky #3 i can control the blower fan evan if the van if off and the keys are in my hand #4 then engine seems to be running rough a bit a idle #5 when driving it seems as if its fine for a min the next its chuging as if the coil pack is shot so i changed it that made no diff. ok so about the engine light i borowed my friends obd ready and this is what happen after driving for about 15 mins i put the meader on with the van runing and i got thease 7 codes p0443 p0134 p0353 p0351 p0703 p1391 p1398 so then i turned the van off then just to the on position and cheacked again and it says there no codes lol so then i start the van and try this again cause the light is still there now its saying theres only one code wich is p0353 so then i go for a ride and try it again with the van runing and the 7 codes came back any ideas cause im lost lol
Sep 23, 2009 at 6:17 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect a wiring issue and or a disconnected plug and or its not all the way in
tranny shop should recheck the work they did and check the wiring harness
Sep 26, 2009 at 11:48 PM
