1996 Dodge Caravan
JNTAHUTCH
Engine Mechanical problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
The dodge caravan at first had just quit running and when I finially got it started I drove it home, and as I truned the van quit again. I got it started once again and got it home. I changed the fuel filter thinking that it was the problem, and drove it again and it quit again. The fuel pump is doing it job, but could it be the map sensor or what do you think. Thanks
May 12, 2009 at 9:58 AM
  • 75,988 POSTS
Check the fuel pressure to rule out a failing fuel pump
May 12, 2009 at 10:03 AM
