1996 Dodge Caravan
10,200 MILES • 6 CYL • FWD • AUTOMATIC
WISHMAN
my 1996 dodge carvan 3.3 liter will crank over but it will not start.can you tell me how to check the timing belt. or do you think it could be. the crankshaft sensor or camshaft sensor.or the ecm and how to check them. i would appreciate your time and answer. thank you sign. wishman
May 9, 2009 at 11:14 AM
BMRFIXIT
  • 19,053 POSTS
3.3L engine has no timing belt
for no start condition check for spark and check for fuel
not sure how check our video collection
https://www.2carpros.com/video.htm
cycle ignition key ON OFF ON OFF ON read codes if any in the odometer area
with key on do you have check engine light on
crank engine does the light go off
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 9, 2009 at 1:09 PM
