1996 Dodge Caravan
197,444 MILES • 6 CYL • FWD • AUTOMATIC
DONALDWILLIS
our van will start up and idle fine but when you peddle down it wants to die we have replaced the fuel pump and the fuel filters as we were told and we still have the same problem do you have any other suggestions thanks
Mar 7, 2009 at 4:45 AM
JDL
  • 16,098 POSTS
Hello, If I thought it was a fuel issue, I'd check fuel pressure first thing. You need a fuel pressure gage., if your going to work on your own vehicles.
Can you check for codes? Some of the national brand autostores will check codes for free. It just sounds like the system is going lean for some reason.
Mar 7, 2009 at 5:33 AM
