1996 Dodge Caravan
150,000 MILES • 6 CYL • FWD • AUTOMATIC
JAYMAN74US
my van runs rough on freeway does what seems like a hard miss and when does this the speedometer drops out and resumes after miss I changed egr witch was only fault code now no codes but problem remains I found clues to speed sensor or throttle pos sensor or pcm do I have to change them all or is there a way to figure witch sensor is faililg
Nov 28, 2008 at 8:56 AM
DOCFIXIT
  • 18,828 POSTS
Probably VSS cause speedo drops out with miss.
Nov 29, 2008 at 5:49 AM
