1996 Dodge Caravan
204,000 MILES • 6 CYL • 2WD • AUTOMATIC
GHV2000
i have a noise and a shake coming from the left rear breake
it is all new in both sides drums and shoes
it does the problem only with the break pedal at any speed no with the parking brake
the right side is perfect
looks like there is a problem with the hydraulic fluid wich is new and the system has beem bleed and adjusted following the maintenance manual
any idea????
could be the bearing????
i jacked up and turning the wheel by hand and sound like somethig is out of center
thank for your help
Oct 29, 2008 at 4:27 AM
  • 110,246 POSTS
Hi:
Are you refering to the rear brakes? Have you removed the wheel and drum to check if anything is broken?
Oct 30, 2008 at 6:46 AM
GHV2000
yes i did
everything is brand new except for the bearings and only on the left rear side
Oct 30, 2008 at 7:02 AM
  • 110,246 POSTS
Hi:
If everything is new except the bearing, check it for play and check the spindal for wear. Also, check the rear axle for bushing problems.
Please let me know what you find. I would like to know if it's the bearing.
Oct 30, 2008 at 10:57 AM
GHV2000
found the problem
was air on the line
we bleed the brakes air came out an there's no more sahking
Dec 4, 2008 at 3:19 AM
