1996 Dodge Caravan
171,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONICAW4
I hava a 96 dodge grand caravan and my car is backfiring, loosing power, and cutting off. I have replaced the fuel pump, fuel filter,map sensor, ignition coil, and the throttle body sensor and the same problem is still happening.
Oct 12, 2008 at 4:37 AM
BMRFIXIT
  • 19,053 POSTS
if its stalling I would suspect the crank sensor \ check also ASD relay
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 12, 2008 at 11:48 AM
