1996 Dodge Caravan
ISMAEL LOPEZ
Engine Cooling problem
1996 Dodge Caravan 6 cyl Front Wheel Drive Automatic
can't find the temperature sensor in the van. by the mecanic book there is a temperature sensor and a termostat temperture sensor. the check engine light its given the temperature sensor. is the termostat sensor the same or is there two sensors in the van?
Aug 13, 2008 at 3:04 AM
ROB2008
  • 258 POSTS
Under hood, passenger side, upper engine area, above water pump, mounted in intake manifold
let me know if that's the right location ..
Aug 13, 2008 at 3:27 AM
