1995 Dodge Caravan won't move
1995 DODGE CARAVAN
145,000 MILES • 6 CYL • FWD • AUTOMATIC
CC13
van starts and runs good always has. engine was replaced around 40,000 miles by a dealer.(bad rod bearing)1n 2000 transmission was worked on by aamco and was sent back two times for rework due to leaks. five years ago had transmission resealed due to a leak. no problems up untill now. while driving down the interstate started to shake and make noise pulled off the roadway to a truck stop. at this point the van stoped moving. towed home looked at it. It starts and runs but will not move when put in gear. sounds like the transmission goes in gear but makes noise like a gear or something has sheared off or the diff went out. any idea what it could be?? van is not worth spending $1200 to have it repaired.
May 24, 2008 at 5:30 AM
LEGITIMATE007
  • 5,121 POSTS
check your dipstick for signs of metal chips
May 24, 2008 at 6:53 AM
CC13
Ok i pulled the transaxle end cover. Jacked up the van started it and put it in gear tires turn. placed on ground and nothing but a bad noise. (output shaft stops turning).i'm guessing at this point it's going to need a overhaul.
May 24, 2008 at 10:56 AM
LEGITIMATE007
  • 5,121 POSTS
you know , this is a common problem with these vans, and it sucks because they are a really good vehicle to have.. I have one to which I am in the process of replacing a couple of valves, but there is always that question in the back of my mind, is the tranny gonna end up going bad? . You sound like you know pretty well what your doing, and your diagnosis is 100% correct. I hope that eveything turns out ok and please keep in touch..... talk to ya later
May 24, 2008 at 1:19 PM
