, I would like to know which transmission fluid I need to use
CALLUM_SMITH64
Hi, i would like to know which transmission fluid i need to use in my car. I have found a transmission fluid that might work, but it states that it should not be used on a car that has a nag-1 transmission. does my car have a nag-1 transmission? thanks kate
Aug 28, 2009 at 5:25 AM
JALOPYPAPA
  • 467 POSTS
Your car uses ATF Plus 4 Type 9602 Oil Type .................... Mopar (R) ATF Plus 4 Type 9602, Or Equivalent.
Here is a guide that will help you service the transmission by walking you through the steps.
May 21, 2021 at 8:07 AM
