1995 Dodge Caravan Van won't start
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOVEBEINAMOM
How do you know if your started is going out? Last week this started where it would take 3 or 4 tries to start and would finally start, then yesterday nothing. I have changed the starter fuse today, and the battery cables 3 years ago along with the battery. Had the battery checked out and still is good.
How do I know if it is the cables or the starter?
May 23, 2008 at 5:40 AM
BLACKOP555
  • 10,386 POSTS
if the starter is going out the vehicle will not crank or crank slowly or just sit there and click.
best way to have it tested is take to the shop.
May 23, 2008 at 6:04 AM
LOVEBEINAMOM
Thank you, It actually doesn't click, it just does nothing. As soon as I can find a way to get it to a shop I am hoping to get it looked at.
May 23, 2008 at 12:19 PM
BLACKOP555
  • 10,386 POSTS
you could have a bad starter or starter solenoid.
but since it does it on and off, i would suspect that it may be the igntion switch that may be faling you.
May 24, 2008 at 1:59 AM
