1995 Dodge Caravan TIMING BELT REPLACEMENT
80,000 MILES • 6 CYL • FWD • AUTOMATIC
JEAN MANUEL
PLEASE I WANT TO KNOW THE AVERAGE MILAGE TO CHANGE TIMING BELT ON CARAVAN SOME PEOPLE TELL ME 60,000 SOME 120,000 WHO'S RIGHT
THANKS
Nov 9, 2009 at 7:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
which engine ? 3.0L , 3.3L etc..?
Nov 9, 2009 at 7:17 AM
CARADIODOC
  • 34,397 POSTS
60,000 miles isn't soon enough for some older Hondas, but for your engine, it's common for the belts to last well over 150,000 miles. Mine has WAY more than that on it. This is not an interference engine so nothing will be damaged when the belt breaks. The only concern is sitting on the side of the road and paying for a tow truck.
A common cause of timing belt failure is worn bearings in the water pump. In my case, I had many weeks of warning that the pump was going out. (Noise and coolant leaks).
caradiodoc
Nov 10, 2009 at 5:12 PM
