The heater stopped heating and the temperature gauge stays on c. How do I replace the thermostat?
Dec 27, 2008 at 9:41 AM
✓Experienced Mechanic
Hi:
drain coolant from the radiator. Next, follow the upper rad hose back to the engine. The hose will end at the thermostat housing. Remove the hose, unbolt the housing and the t-stat is under there.
