1995 Dodge Caravan thermostat
90,000 MILES • 6 CYL • FWD • AUTOMATIC
ROGER DENT
The heater stopped heating and the temperature gauge stays on c. How do I replace the thermostat?
Dec 27, 2008 at 9:41 AM
  • 110,244 POSTS
Hi:
drain coolant from the radiator. Next, follow the upper rad hose back to the engine. The hose will end at the thermostat housing. Remove the hose, unbolt the housing and the t-stat is under there.
Replace the thermostat and reverse the process.
Dec 27, 2008 at 3:56 PM
