1995 Dodge Caravan the van will not start
WATTERS33
Engine Mechanical problem
1995 Dodge Caravan 6 cyl Two Wheel Drive Automatic
the van has the 3.0 v6 and it try's to turn over but will not start, we have changed the ignition coil, the plug wires, the battery, it is not the fuel pump or the filter and i have pulled the distributer and it looked fine, one thing though is with the dist. cap off it does not turn when trying to start, do you think it is mechanical or? any help would be appreciated
Jul 19, 2010 at 3:29 PM
  • 75,988 POSTS
The timing belt could be broken or the distributor drive gear sheared off-
Jul 19, 2010 at 3:38 PM
