1995 Dodge Caravan starting
CLAIRSKY
  • 1995 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 142,000 MILES
My engine is a 3.3L and when cold and sitting for a long time, even months, it will start right up. But when it warms up, whether a short or long trip it doesn't matter, after I shut the engine off for a while it takes a lot of cranking to get it started. If shut off and starting right away it is ok, but after a few minutes or hrs. It is very hard starting. Takes seven to ten seconds of constant cranking for it to start and then it seems flooded and takes a while to clear up. I replaced the fuel pump and filter. Any other sugestions? Thank you, Clair
Thursday, April 24th, 2008 AT 11:43 AM
LEGITIMATE007
  • 5,121 POSTS
First make sure your getting air, change your filter if you haven't already.(Air filter that is). Then check your fuel pressure and ignition. After that check wires and make sure they are not corroded.
Thursday, April 24th, 2008 AT 7:51 PM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
check this out for fuel pressure
LEGITIMATE007
  • 5,121 POSTS
Check this out for ignition and spark:
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Thursday, April 24th, 2008 AT 7:52 PM
