1995 Dodge Caravan speedometer
BILLYJOE1
  • 7 POSTS
Engine Mechanical problem
1995 Dodge Caravan 6 cyl Two Wheel Drive Automatic
my speedometer cuts in and out on me ,especially when it rains .....how do i go about repairing it.......and where abouts is the cable located.....thanks..
Mar 4, 2009 at 4:10 AM
YESAC1354
The Transaxle Control Module (TCM) calculates vehicle speed based on input received from Input and Output speed sensor mounted on the transaxle.you should inspect the wires going to the sensors to see if there is any broken or frayed wires
Mar 5, 2009 at 10:17 AM
BMRFIXIT
  • 19,053 POSTS
check and suspect speed sensors you have two input and output similar to this
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic9_10.jpg
Mar 5, 2009 at 10:31 AM
