Transmission problem
1995 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have a 1995 Dodge Caravan SE, with a 3.0 motor,
four speed overdrive transmission.
This (trans) was rebuilt 3.5 years ago.
When you drive the van the transmission after it warms up slips from D to 2nd gear, sometimes when you stop and start it the transmission will not go into drive. when you pull over put the van in park and re-start it it is fine.
when you drive it for long periods of time it gets worse. You have to keep pulling over shutting it off and again re-starting it.. Please help, any answer's ?
Thanks
Thanks
Apr 10, 2009 at 8:31 AM
