1995 Dodge Caravan Opening Hood to add fluid
189,000 MILES • 4 CYL • 2WD • AUTOMATIC
JEANW
I regularly add transmission fluid as there is a small leak (not worth paying to repair/replace at this point). Yesterday could not get hood open. Appears the lever broke, but even after reaching the cable, could not get it to unlatch so I could open it to add transmission fluid and oil. Any suggestions?
Mar 12, 2009 at 2:45 AM
JALOPYPAPA
  • 467 POSTS
Remove the front grille and that should give access to the latch mechanism. The release cable may be broken.
Mar 12, 2009 at 3:12 PM
