1995 Dodge Caravan lower radiator hose and water pump
18,000 MILES • 6 CYL • FWD • AUTOMATIC
IHOPSNOW
1995 dodge caravan w/ 180,000km. I am trying to find out the name to a part that needs replacement. It connects the lower radiator hose into the engine block. The lower radiator hose is the usual rubber, but the piece that i am trying to find out is alluminium and has a split that goes up through the firewall to the heater core. I went to a parts store and they had no clue what i was talking about and i can't find out what it is on the internet. Also there is no part number on it. Can you tell me what this part is called?
Also i have a water pump leak. I was wondering if i have to replace the pump because i don't notice a change in the engine, accept that i have to fill up the rad resivoir constantly. Could a seal just be gone or is it the pump? Also about how much do water pumps go for($$)?
Jun 4, 2008 at 4:27 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c4765be8d7="ihopsnow"]Engine Cooling problem
1995 Dodge Caravan 6 cyl Front Wheel Drive Automatic 180,00 miles
Also i have a water pump leak. I was wondering if i have to replace the pump because i don't notice a change in the engine, accept that i have to fill up the rad resivoir constantly. Could a seal just be gone or is it the pump? Also about how much do water pumps go for($$)?[/quote:c4765be8d7]
OK, I am not sure what the part name is. I am sure that it is a Dealer Part Only and that is why you are unable to find it.
The water pump should be replace it shouldn't cost you anymore than $50 for the pump.
Jun 8, 2008 at 4:03 PM
