1995 Dodge Caravan loss of coolant
140,000 MILES • 6 CYL • FWD • AUTOMATIC
RSCARAVAN
  • 5 POSTS
The system pressure checks ok. no water in the oil. no steam out of the tail pipe. no visible coolant leaks, engine or ground. new cap. I am baffled where is the coolant going. I filled the system about 700 mi. ago, added another gal. 50/50 YESTERDAY, not even showing in the radiator tank, nor in the resevoir. Is there something peculiar about the caravan? Thanks for whatever help you can provide...RL
Feb 5, 2009 at 8:54 AM
  • 110,244 POSTS
Good question. Check the carpet on the passanger side of the van. Maybe the heater core is leaking.
Let me know what you find.
Feb 5, 2009 at 11:12 AM
RSCARAVAN
  • 5 POSTS
Joe, passenger side dry..... and Still baffled..RL
Feb 6, 2009 at 10:32 AM
  • 110,244 POSTS
Did you pressure test the cap?
Feb 7, 2009 at 9:49 AM
RSCARAVAN
  • 5 POSTS
NEW CAP PRESSURE TESTED OK...RL
Feb 8, 2009 at 1:15 PM
  • 110,244 POSTS
If there are no leaks, it has to be getting into the combustion chamber. Are you sure there is no white smoke from the exhaust? Also, you may want to check compression to see if one of the cylenders are low.
Feb 9, 2009 at 1:15 AM
RSCARAVAN
  • 5 POSTS
Yesterday about a block from home the temp. gauge began to rise abnormally. I parked the van in the garage filled the system and pressure checked it. I brought the press. to 16 psi., it held for a few seconds and then rapidly bled off. The leak was now visible. Tomorrow I'll pull the right tire and wheel pan to determine the exact location of the leak and let you know; then we can all sleep...RL
Feb 9, 2009 at 9:29 AM
  • 110,244 POSTS
If it's on the right side, I bet it's the waterpump. Let me know. I'm anxious to know what it is.
Feb 10, 2009 at 5:01 AM
RSCARAVAN
  • 5 POSTS
Jacob, you were right it was the water pump. But, why could I lose so much coolant from the water pump and not see it on the ground until the seal really let loose. 45 bucks and a few hours labor problem resolved,two days driving no loss of coolant. The 5 bucks I sent , keep it, I enjoyed the education and banter...RL
Feb 12, 2009 at 9:24 AM
  • 110,244 POSTS
Thank you, and I'm glad it's fixed. It's hard to tell what happens at times with things like coolant. There have been some cars I felt needed a priest more than a mechanic.
Take care, and if you ever have questions in the future, let us know.
Feb 12, 2009 at 10:16 AM
