1995 Dodge Caravan Leaking Gas
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHCEML
I found my Caravan leaks gas in the injecter or fuel pressure regulater are, and I can not pin point the location. When the engine is warm there is no leaking, but when the temperature around 30 F degree,it leaks gas very bad.
I took the car to the dealer for service,they can not find out the problem. anyone can tell me what is wrong ? Thanks
Henry.
Jul 7, 2009 at 3:31 AM
  • 110,244 POSTS
If the leak is near the fuel rail, chances are there is a bad O-ring on one of the injectors (where it enters the engine). This, however, is odd for a Chrysler product. If you remove the vacuum line from the regulator, does it leak?
Jul 15, 2009 at 5:29 PM
