1995 Dodge Caravan head gasket
162,000 MILES • 6 CYL • FWD • AUTOMATIC
TOM SMITH24
I got antifreeze in the engine I need to change the headgasket but right now It won't turn over probable because of the antifreeze in the engine.Is ther any thing I can do to get It starte toget it home and In my garage .The van is about 3 blockes from my house
Feb 4, 2009 at 4:23 AM
  • 110,244 POSTS
If there is coolant in the cylender not allowing the engine to turn over, the only thing you can do is locate the cylender with the coolant and vacuum it out. If the engine can turn over, it may start then if there is enough compression. Keep in mind, if the oil is contaminated with coolant, it could damage bearings, cylenders, valves...
Feb 5, 2009 at 11:44 AM
