1995 Dodge Caravan Fuel pump fuse
153,000 MILES • 6 CYL • FWD • AUTOMATIC
ATREIDES-451
While my engine turns-over fine it gives no indication of trying to start. When I checked the fuses, the fuse for the fuel pump was blown. I replaced the fuse, tried to start the van again, same problem, fuse blew again. Even though I know you aren't supposed to, I tried using a heavier fuse (25 amp ILO 15 amp), with the same result of a blown fuse. Can I find out the possible causes for this please?
Jan 30, 2010 at 4:21 PM
  • 75,988 POSTS
Disconnect the fuel pump connector and see what happens-fuse blows remove fuel pump relay -
Jan 30, 2010 at 4:25 PM
