1995 Dodge Caravan Engine will not stop
FARMERDAVE17331
1995 Dodge Caravan 4 cyl Automatic 180,00 miles
All of a sudden our engine will not stop when the switch is turned off. You can even pull the key and it stays running. Everything else turns off as normal. The air bag light and oil light stay lit. What happened?
May 14, 2009 at 2:40 AM
BMRFIXIT
  • 19,053 POSTS
Check and suspect ignition switch
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 14, 2009 at 11:06 PM
