1995 Dodge Caravan engine cranks but will not start
KAREPEYRKO
MEMBER
1995 DODGE CARAVAN
6 CYL
FWD
AUTOMATIC
185,670 MILES
When I turn on the key the engine will crank but there is a weird noise and will not start. Also a check eng light apperars.
Saturday, April 4th, 2009 AT 4:38 PM
CARADIODOC
MECHANIC
There's 84 different kinds of "weird" noises. If it's a banging or metallic clanking sound, suspect a cracked flex plate. That can cause a no-start condition. The Check Engine light staying on means a diagnostic fault code has been memorized by the engine computer. Possibly a failure of the crankshaft position sensor to detect the holes on the flex plate. That will create the no-start.
