1995 Dodge Caravan distributor problem
TERYLGAR
Electrical problem
1995 Dodge Caravan 6 cyl Front Wheel Drive Automatic
Hi - '95 natural gas Caravan, 3.3L. The under-hood fuse blew that powers the engine electrical. One section of the 3-section distributor had overheated, and actually cracked. Replaced the distributor, ran well for awhile, then same section (plugs 3,6) overheated and blew the fuse. Cutting the wire feeding the 3,6 coil keeps the fuse from blowing. I rigged a good section of the old distributor to replace the blown section, that works for awhile and then the fuse blows. I've replaced the plug wires, but not the plugs. Any suggestions?
Nov 12, 2008 at 1:43 PM
2CARPRO JACK
  • 11,533 POSTS
3 section distributor? you mean 3 coils? If it blows the fuse for a specific coil,then the coil may be the problem,it could be shorting internally when it gets hot
Nov 13, 2008 at 9:19 AM
