Just purchased a 1995 Dogdge Carvan with hundred thousand miles on it. Everything seems to work ok except the heater. I flushed out the heater cord by diconnecting the heater hoses and flushing out the core with a water hose. done in both direction and water came out clean. Replaced the thermostate with 195 deg. Ck the heater control value. was open. Not sure of the vacumn connection or if it had any vacumn at all but the value was fully open. I worked manually and it opened and closed when I pushed it. The hoses seem to be quite hot after I put things back together but the temp coming out of the grill is only 95 deg. The temp gauge on the dash reaches about the third line on the gauge. Don't know if it should be higher. Don't kow the location in normal operation. Please advise
Oct 16, 2009 at 5:23 AM
