1995 Dodge Caravan cranks but no spark or power to coil
TRUCK13
Electrical problem
1995 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Ck.engine lt. came on while driving serpentine belt had previously fallen off several times. Changed pulley. Now car cranks but will not start. No power at injectors. Could it be the PCM went bad . What else could it be?
Jun 27, 2008 at 2:33 AM
DOCFIXIT
  • 18,828 POSTS
Could be crank sensor, going to need to check for codes.You can get a code reader for @$30
Let me know what you get
Jun 27, 2008 at 4:00 AM
TRUCK13
put in a new crank sensor, cam sensor, tried another PCM and coil, still does not start. Checked all fuses and relays and checked fusible link at distr. box. Tried putting key in door to reset Nothing I tried made any difference. Checked codes with ignition and the only code that came up was 54 which says no cam signal at PCM. Before I switched PCM's code 42 came up which say's an open or shorted condition detected in auto shut down relay circuit
Jun 27, 2008 at 8:58 AM
DOCFIXIT
  • 18,828 POSTS
Ohm check wiring from cam sensor to pcm see if wiring is an issue. So code 42 no longer comes up?
Just 54 so check wiring to pcm.
Jun 28, 2008 at 2:44 AM
