1995 Dodge Caravan Crank Angle Sensor
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARTYANDDANNY
I have been told that I have a faulty crank angle sensor which often keeps the engine from starting.
Where is the crank angle sensor located?????
Jun 15, 2010 at 2:17 PM
BMRFIXIT
  • 19,053 POSTS
On transaxle bellhousing
Jun 15, 2010 at 2:33 PM
MARTYANDDANNY
Thank You very much.
Jun 15, 2010 at 3:12 PM
MARTYANDDANNY
Is the sensor you are referring to on the transaxle the Cam Position Sensor or the CRANK ANGLE SENSOR.
I need the crank angle sensor which effects the starting of this vehicle.
Jun 15, 2010 at 3:55 PM
JALOPYPAPA
  • 467 POSTS
MartyandDanny, BMRFIXIT was correct. Your crank angle sensor is mounted on the transmission bellhousing, specifically, on the rear near the top. Most easily seen from under the car.
Jun 16, 2010 at 5:48 AM
BMRFIXIT
  • 19,053 POSTS
yes the crank sensor
look for it at the side of the firewall of the bell housing
lower side from top
best if you buy new one so you have it to compare
Jun 16, 2010 at 8:30 AM
MARTYANDDANNY
Once again - thanks -
I had another person try and say that possibly it was the other sensor.
Thanks for the description - it will now be easier and yes - it will be replaced.
Marty
Jun 18, 2010 at 1:17 AM
