1995 Dodge Caravan axles
205,000 MILES • 6 CYL • 2WD • AUTOMATIC
LITDALE
i replaced left-sde 4 months ago then right side today i test drove still vibretions when exeleration and turning i think the left side has gone bad but dont know why
Jul 4, 2010 at 11:03 AM
  • 110,251 POSTS
Are you sure the wheel bearings are good?
Jul 4, 2010 at 4:43 PM
LITDALE
yes just replaced them both sides
Jul 5, 2010 at 6:14 AM
  • 110,251 POSTS
If you replaced everything and there is no bent rim, I think you're right, the left side is bad again. If the part was purchased as an aftermarket part, it isn't uncommon for them to be poorly manufacturered parts. Does it feel like there is any play at the joints?
Jul 5, 2010 at 1:25 PM
  • 110,251 POSTS
After thought... are the motor mounts and trans mounts in good shape?
Jul 5, 2010 at 1:26 PM
