1995 Dodge Caravan at a loss
151,405 MILES • 6 CYL • 2WD • AUTOMATIC
KYLE BRAFFORD
I was driving my van and came to a stop sign to make a left turn and when i went to turn the van would not push over 2000 rpms and had no power. i could barely get to 20 miles an hour. then when i get to the bottom of the road it acted fine.but when i pulled on my street it started doing the same thing. its got me baffled and aggravated so if you can help will gladly take all imformation.i dont want to replace one thing and that not be it
May 23, 2009 at 2:27 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked fuel pump pressure? Also, check to make sure the catylatic converter isn't starting to plug. Listen for hissing or ratteling from it.
May 27, 2009 at 2:02 PM
