1995 Dodge Caravan analog instrument cluster
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARTHURWITH7
vehicle has an analog instrument cluster and everything on the cluster stopped working for about 2 days. even the odometer quit working. has worked fine now for 3 days. any ideas?
Nov 24, 2009 at 9:59 AM
CH112063
  • 1,320 POSTS
The power fuse is located under the hood, and it's ground is either side kick panel. You may have to remove two trim panels on both sides. And behind the cluster, the connector is another spot. The whole power passes through the large firewall bulhead connector. Behind the left strut. This circuit usually has problems at that bulkhead connector(50 wat connection. You'll sometimes see green corrosion
Nov 24, 2009 at 1:58 PM
