1995 Dodge Caravan
THEMEAT50
  • 1995 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 130,000 MILES
While driving down the road, the motor is turning off and on, and the speedometer will go from zero to the speed I am going as the engine jerks. It seems like someone keeps flooring the gas and then lets up. I replaced a complete distributer, the throttle body, fuel filter, and a speed sensor and the problem has not been fixed. Do you have any answers?
Sunday, August 8th, 2010 AT 9:17 PM
  • 109,885 POSTS
Have you checked all connections to the PCM to make sure they are clean and tight? Has the check engine light come on? Have you checked fuel pump pressure?
Sunday, August 8th, 2010 AT 10:50 PM
