Serpentine Belt and Throttle Body Sensor
3.3L • 6 CYL • FWD • AUTOMATIC
MICHAELEUGENE1965
  • 6 POSTS
After my serpentine belt broke my throttle body sensor went bad. Why did this happen, and how do I fix it?
May 3, 2014 at 7:13 AM
CARADIODOC
  • 34,416 POSTS
If you're referring to the throttle position sensor, they have a very low failure rate, and it isn't related to the belt. You repair it by replacing it. What symptoms or problems led you to the sensor?
May 3, 2014 at 7:22 AM
MICHAELEUGENE1965
  • 6 POSTS
The check engine light came on, and when I tried replacing the sesor, my car was still getting too much gas, as well as it was still smoking.
May 3, 2014 at 7:30 AM
MICHAELEUGENE1965
  • 6 POSTS
I meant sensor.
May 3, 2014 at 7:34 AM
CARADIODOC
  • 34,416 POSTS
The TPS has almost nothing to do with how much fuel goes into the engine. Now you're mentioning smoking too. Please start at the beginning and include all the details. The Check Engine light tells us there is a diagnostic fault code stored in it. Have you read that code? What was smoking? Out the tail pipe? The new belt? Oil on the engine, etc.
May 3, 2014 at 7:57 AM
MICHAELEUGENE1965
  • 6 POSTS
My serpentine belt broke in my driveway. When I replaced it, my car's check engine light came on, and the check engine light told me that my map sensor (I'm sorry for not mentioning this before) and throttle body sensor went bad. I replaced both sensors, but my car started to run as if it was getting flooded with too much gas, which it never has done before.
May 5, 2014 at 9:38 AM
MICHAELEUGENE1965
  • 6 POSTS
Al my lights are on as well, and my oil light is on when the car is on.
May 5, 2014 at 9:48 AM
CARADIODOC
  • 34,416 POSTS
Dandy. The first thing you must be aware of is diagnostic fault codes never say to replace parts or that they're bad. They only indicate the circuit that needs further diagnosis. About half of the time the sensor referenced in a code is actually defective, but the other half of the time, especially when there's two related codes, it's a wiring problem related to them. In this case, both sensors share a common 5.0 volt feed and a common ground wire. A break in either wire would trigger both codes. It's much more likely a shredded serpentine belt flung a piece around that cut a wire. Those sensors are pretty tough, and they're not close to the belt, so testing the wiring is the next step.
Unplug either sensor and measure the three voltages on the three wires with the ignition switch on. (That alone will also set a fault code). You should find 5.0 volts on the feed wire, 0.2 volts on the ground wire, and 5.0 volts on the signal wire in the middle. That signal wire voltage should drop to around 0.5 volts if you plug the sensor back in and back-probe through the rubber seal around the wire.
May 5, 2014 at 1:06 PM
