the van has been sitting for two years and we had it running, but not it won't start. it turns over fine and but won't chatch. what do i do?
Mar 22, 2008 at 11:37 AM
BMRFIXIT
✓Experienced Mechanic
if it sat for two years check if the fuel is still good
check if fuel pump is coming on and you have fuel pressure if not give the mid of tank a couple of good hits whill a helper is trying to start and if start this way the fuel pump is no good
also check for spark at the spark plug wire
if no spark check or replace crank sensor
also check it for tune up cap rotor wire ....
good luck
