1994 Dodge Caravan Wiper arm
KJOHSON1984
1994 Dodge Caravan
My passenger side wiper arm does not work, I have the service manual and it says to pop off the cap that exposes the nut and tighten that up however when i popped it off it had another cap, kind of looks like a milk carten cap, instead of a bolt, I figure the nut is underneath that cap but, its stuck, I tried everything and it will not budge. know of any products or tools i can use to un stick it?
Jun 10, 2010 at 7:02 AM
  • 110,248 POSTS
The other cap shouldn't be there. It sounds like someone had problems before and wedged something over the shaft so it would work. Are you able to tell if there is a nut under the cap?
Jun 14, 2010 at 5:16 AM
KJOHSON1984
The ridged cap I am speaking of is actually located underneath both of the wiper arm caps. I believe they are supposed to pop off with the actual caps themselves. I cannot see any bolts underneath.
Jun 14, 2010 at 6:10 AM
  • 110,248 POSTS
Honestly, the cap that I'm refering to is black and looks like part of the arm. It is hinged on one side and when opened, it should expose a nut that holds the arm in place.
Jun 14, 2010 at 6:47 AM
KJOHSON1984
I know exactly what your talking about, when I lift the cap that is hinged to the arm the only thing it exposes is a cap that has groves on it and and x in the middle, I have tried to unscrew the other caps and they do not budge, I have also looked in the repair manual and owners manual to see if they mention anything about them and they don't.
Jun 14, 2010 at 7:00 AM
  • 110,248 POSTS
That is interesting. I have never see one like that. I will do further research to see if I can find something different and let you know what I find. Can you take a picture of it and upload it for me to see?
Jun 14, 2010 at 7:26 AM
KJOHSON1984
I will take a picture this afternoon, thanks so much. :)
Jun 14, 2010 at 7:31 AM
