1994 Dodge Caravan Van has trouble starting
180,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGA85
I recently jumped someone off and drove my van around about 4 miles before parking it at home. Next morning I tried to start the van and it would not start acted like it would but didnt, finally we got it started but when you press on the gas the van sputters and dies if you ease on the gas the van will go and you can apply more gas the faster it is going. I have changed the plugs and wires, o2 sensor, idle intake control valve, air filter fuel filter, have tried without air hose on tried plugging up egr to check everything is still the same. Maybe fuel pump or could somehow the battery have a problem since it was so sudden van ran great prior to jumping have reset ecm and no error codes when doing ignition diag. only 12 and 55 which are very common.
Apr 28, 2009 at 5:15 AM
BMRFIXIT
  • 19,053 POSTS
Check fuel pressure check exhaust system and it flow
Apr 28, 2009 at 2:26 PM
