1994 Dodge Caravan tranny
1994 DODGE CARAVAN
244,567 MILES • 6 CYL • FWD • AUTOMATIC
JEFF35
transmission works great forward,some times you have to turn ing. off and on real quick to shift into OD. the reverse went out but it still drops into reverse but starts to shutter and will not pull when you press gas. but if u let it idle it pulls some.st just wondering if it may be shifting sincer
Aug 20, 2010 at 1:48 AM
  • 110,244 POSTS
It sounds like the reverse band has broken or needs adjusted.
Aug 20, 2010 at 2:10 PM
JEFF35
how do you adjust or replace reverse band?
Aug 21, 2010 at 1:16 AM
  • 110,244 POSTS
You need to disassemble the transmission to replace it.
Aug 21, 2010 at 2:02 PM
