1994 Dodge Caravan STARTS WHEN IT WANTS TOO
70,000 MILES • 6 CYL • FWD • AUTOMATIC
ORTIZ2915
VAN STARTS UP AT TIMES AND RUNS GOOD,FOR DAYS.BUT AT TIMES HAVE TO TURN THE KEY ONE OR FOUR TIMES YO START.CAN SOMEONE PLEASE HELP.
Feb 3, 2008 at 4:34 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1d71ac38a0="ortiz2915"]Engine problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic 70,000 miles
VAN STARTS UP AT TIMES AND RUNS GOOD,FOR DAYS.BUT AT TIMES HAVE TO TURN THE KEY ONE OR FOUR TIMES YO START.CAN SOMEONE PLEASE HELP.[/quote:1d71ac38a0]
you turn key on and start
does engine cranks but no start or no crank?
Feb 3, 2008 at 11:03 AM
ORTIZ2915
WHEN I TURN THE KEY THREE IS NO CRANK,NOTHING AT ALL HAPPENS.I HAD TWO FUELPUMPS INSTALLED,SPARKPLUKS & WIRES.
Feb 5, 2008 at 11:19 AM
BMRFIXIT
  • 19,053 POSTS
[quote:24f1a4eebf="ortiz2915"]WHEN I TURN THE KEY THREE IS NO CRANK,NOTHING AT ALL HAPPENS.I HAD TWO FUELPUMPS INSTALLED,SPARKPLUKS & WIRES.[/quote:24f1a4eebf]
still not getting what you mean !!!!!!!!!!
but if it cranks & it doesn't start (engine turn but no start)
check if crank sensor any good
and if engine wont turn check battery check starter and starter relay
Feb 5, 2008 at 11:34 AM
HARLEYPIG
I had a 1993 do the same thing, it was the ignition switch itself....once I replaced it the van started perfectly fine everytime....
Feb 10, 2008 at 7:49 AM
