1994 Dodge Caravan shift handle
CCMANRIQUEZ
Engine Mechanical problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic
the handle you use to shift is boke were it connects inside the steering column. what is it called? how much is the part.
Feb 22, 2010 at 5:05 PM
CARADIODOC
  • 34,413 POSTS
This would be a good question for the dealership parts department. They will have a picture of the steering column on their computer. If just the lever is broken, there is a roll pin to drive out, then just pull off the remaining part of the lever.
caradiodoc
Feb 23, 2010 at 12:02 AM
