1994 Dodge Caravan shaking
111,978 MILES • 6 CYL • FWD • AUTOMATIC
KATHYWVCUT
startup van ,start going down road it starts to shake really bad llike the whole motor is coming out
let off the gas and it stops shaking
hit gas starts to shake bad and takes alot to pick up speed
Jun 1, 2009 at 2:41 AM
JALOPYPAPA
  • 467 POSTS
assuming it's not an engine performance problem like a misfire under load, you might have open the hood, have a helper start the car and shift through the gears with the brake on while you, standing beside the car, watch what the engine does. If it twists more than slightly, you'll need new to replace the two motor and one transmission mounts.
Jun 1, 2009 at 4:58 AM
