1994 Dodge Caravan Oil Pressure
291,000 MILES • 6 CYL • FWD • AUTOMATIC
PAMCHEL
Whenever my 1994 Grand Caravan idles, the oil pressure gauge drops and the check gauges light comes on. What could be causing this low oil pressure? If it is a bad oil pump, how difficult would it be to replace?
Mar 7, 2009 at 3:01 PM
  • 75,988 POSTS
You need to actually check the oil pressure with a mechanical gauge if normal replace the oil pressure sending unit abnormal could mean oil pump and engine bearings-
Mar 7, 2009 at 11:51 PM
