1994 Dodge Caravan oil leak
SIDKOSTER
Engine Mechanical problem
1994 Dodge Caravan 6 cyl Front Wheel Drive Automatic
oil was leaking from this 1994 dodge caravan, so i replaced the oil pan and oil pan gasket. it's still leaking from around crank shaft area, like it's coming from off the top of the oil pan. any idea where it could be coming from? thanks
Apr 6, 2010 at 7:49 PM
CH112063
  • 1,320 POSTS
Is this a 3.0L or a 3.3L? There is the round crankshaft oil seal in the rear. The oil pan is right up against that seal retainer.
Apr 7, 2010 at 2:02 PM
