Hi! i have a 1994 dodge caravan v6 it starts, it runs. but it has a serious oil leak. i put 4 quarts of oil and in less than 15 mins the oil is in the ground. wasted. before it happened, it had a constant whistling sound coming from the engine. when i start it. im not sure what it is, nor did i had someone check it. the van runs when you start it, it's just the serious oil leak. there is no black smoke coming from the tail pipe also. some one said its a crank shaft seal, or something similar. THANK YOU!!!
Nov 24, 2008 at 9:30 PM
