1994 Dodge Caravan No cold air
KJOHSON1984
Air Conditioning problem
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic
I recently purchased 1994 dodge caravan. The blower motor is fine, the heater works fine, the refrigerent pressure is fine and I can also hear the compressor start. I checked all the fuses and they are all fine. What else could be causing my airconditioner not to blow cold air? and how do I fix it? Thanks so much
Jun 10, 2010 at 6:44 AM
  • 110,244 POSTS
If the system is working, have the blend air door checked. It determines if you get heat or AC into the vehicle.
Let me know what you find.
Jun 14, 2010 at 5:17 AM
