My heater has the option to blow heat out of the following.
Main vents, Main vents & Floor, Floor, Defrost
The problem is this is what it blows.
Floor, Floor, Floor, Defrost
I can't get any heat out of the main vents.
I made sure the heater controls are fine. Obviously the blower motor and heater core are fine. I traced all the vacuum lines from the controls to the corresponding canisters and made sure they are moving properly. A while back the heater only worked on high so I replaced the resistor pack from a salvage yard. If I shut the heater completely off and then turn it on a low speed I will get heat out of the main vents for a few seconds and then hear it close. Please Help!!!
Nov 23, 2008 at 9:37 AM
